Csl mini air
Hi. Can anyone tell me if the csl mini air which is £275 plus vat from security warehouse has any hidden costs attached once installed. I only want to use this to enable the mobile app on a G2-20 to set/unset and push notifications in the event of an alarm activation.
Appreciate any help.
It would need an annual monitoring charge. Its not a one off fee
Which app? Just get ethernet card
The Honeywell Ethernet module will only do event reporting and no panel control or apps.  Also, the SelfMon LCE module, which supported virtual keypad and SelfMon reporting, is now end of life.
Not 100% but I think it’s either set/unset or push notifications. Don’t think you can have both.
I assume you mean G2 only?
As the gx app does do more with the dimension
Yes, the OP's G2 is not supported by the GX app. SelfMon customers who already have an LCE module in their Galaxy G2 system can enjoy push notification and remote virtual keypad using the SelfMon VKP app.
The Dimension and Flex are supported by the GX app. The GX app push notification is a free service, so you just have to wait patiently if there are any issues.
