Flex 20 with 2 RF Rio modules
35 minutes ago, Amps said:
Do you self a favour mate and replace all with Pyronix Enforcer kit.
Lol
I wonder do Honeywell make it this way because they are trying to keep the dimension compatible with the G2 and flex and so on but they still can't get it right for the average DIY user
Even complicated for installers
I have followed your link but in menu 52.60.1 I only see the one batch of 8 RF addresses. you mention enumeration - how do I do that?
Enter engineering mode and remove both portal and rio from the system.
2. Exit engineering mode and remove the devices from the config when prompted.
3. Set the RIO address to 2 and add back to the bus.
4. Enter eng mode and menu 72 to detect the device.
5. Add the portal and then menu 72 to detect it.
You didn't do this yet tho
Yes, I have done that and only have 8 virtual addresses 1021 to 1028.
i have two portals, so where it mentions the RIO I did this with the first RF Portal.
Edited by NPotty
but you only have 20 circuits, you need to use the onboard ones
All sorted, I navigated to the onboard addresses and then used RF options to link it. Interestingly I had issues pairing with Alpha mode so had to select V2, but it’s all working.
