Honeywell Galaxy Flex 20 Configuration.
4 minutes ago, RevolvingSteve said:
:thumbsup:
I am going to have to move 2 x PIR onto 1 zone (failed to take into account the final zone on its own door contact).
TBH I almost put both upstairs PIR's onto 1 zone to start with so it was easier to omit/exclude them from the night arming, so I'm not bothered about now putting them onto 1 zone.
How would I adjust the wiring on zone 11 & 12 given to compile them onto 11, I have the PIR's internally wired like the image below.
Obviously replace '1' 0v '2' with 11 & 12!
How many devices you have in total contacts and pirs
  • Replies 44
  • Views 13.2k
11 x PIR'2, 2 x Door Contacts
My other option is just to leave the other (Non Final) door contact for now and replace with a Wireless one...
So buy an expander as you have a 20 zone panel I thought
Edited by al-yeti
Yes it is, I just don't have the expander to hand so was trying to get it finished today, didn't see a major issue with putting 2x onto 1 zone as they are just 'upstairs' and the manual states it supports unto 10 devices per zone, so I can't be the only person wanting to do this?
I am the one with no knowledge here though, so if there is a good reason why this should not be done, just say, its all learning for me!
Steve
Edited by RevolvingSteve
Steve
Don't that's worst mistake
Work out which sensors you need on now
Think about where you want expander which may just be next to control panel and order one
You will just open more fault finding problems trying to get eol working on sensors paired up when you don't need to
Great advice. Thanks! I'll leave one of the upstairs PIR off for now and order the RIO.
Arghh I removed the door contact and can't remember how I wired it as it only has black/red wire. I think this was just across the zone number and 0v as they don't need 12v?
Correct , with resistors in place
Is it a door contact with no tamper ?
Good bloke you can then also get an RF card later I believe and have wireless zones , unless you already have that
3 hours ago, GalaxyGuy said:
Part entry.
Cheers.
So upstairs PIR are still set to intruder for function, but excluded from night set?
25 minutes ago, RevolvingSteve said:
Cheers.
Sounds ok
