Carlos12 Posted January 19, 2019 Author Share Posted January 19, 2019 (edited) 2 minutes ago, sixwheeledbeast said: Whats on Zone 8? It's likely unrelated to the bellbox being a Zone It says "technical" on instruction manual. only 1-4 zones are used. Technical (TC) (Key in 08). Use this zone type when you want to monitor equipment, for example a freezer, without raising a full alarm. If a technical alarm zone is activated while the system is set, the system makes no audible alarm. However, when a user unsets the system the keypad indicates a fault.If a technical alarm zone is activated while the system is unset then the system starts a pulsed tone from the keypad. If programmed, the control unit also starts communication. When a user enters a valid code the keypad stops the tone and displays the zone. Edited January 19, 2019 by Carlos12 Quote Link to comment Share on other sites More sharing options...
al-yeti Posted January 19, 2019 Share Posted January 19, 2019 2 minutes ago, Carlos12 said: It says "technical" on instruction manual. only 1-4 zones are used. Technical (TC) (Key in 08). Use this zone type when you want to monitor equipment, for example a freezer, without raising a full alarm. If a technical alarm zone is activated while the system is set, the system makes no audible alarm. However, when a user unsets the system the keypad indicates a fault.If a technical alarm zone is activated while the system is unset then the system starts a pulsed tone from the keypad. If programmed, the control unit also starts communication. When a user enters a valid code the keypad stops the tone and displays the zone. Link it or make it used or spare 1 Quote Link to comment Share on other sites More sharing options...
Carlos12 Posted January 19, 2019 Author Share Posted January 19, 2019 Just now, al-yeti said: Link it or make it used or spare Just to clarify, I'm really not used to this, I'm a wood butcher by trade haha. Link CCT7-CCT8, the same as CCT5-CCT6? Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted January 19, 2019 Share Posted January 19, 2019 Just link them all like the white lines on the PCB 1 Quote Link to comment Share on other sites More sharing options...
Carlos12 Posted January 19, 2019 Author Share Posted January 19, 2019 (edited) 4 minutes ago, sixwheeledbeast said: Just link them all like the white lines on the PCB Thanks so much! Will do this, obviously turning everything off first. Edited January 19, 2019 by Carlos12 Quote Link to comment Share on other sites More sharing options...
Carlos12 Posted January 19, 2019 Author Share Posted January 19, 2019 Now the alarm has frozen? It doesn't seem to be responsive, I've taken all my links out, and placed existing back in, battery off, kick started and same issue? I really appreciate your help. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted January 19, 2019 Share Posted January 19, 2019 Just now, Carlos12 said: Now the alarm has frozen? It doesn't seem to be responsive, I've taken all my links out, and placed existing back in, battery off, kick started and same issue? I really appreciate your help. Coms to keypad might be missing check connections to keypad.both ways You have only one keypad yes? 1 Quote Link to comment Share on other sites More sharing options...
Carlos12 Posted January 19, 2019 Author Share Posted January 19, 2019 I'll check all wiring, thanks. Only the one keypad. Quote Link to comment Share on other sites More sharing options...
Carlos12 Posted January 19, 2019 Author Share Posted January 19, 2019 (edited) PERFECT!! We're sorted. Just a few more issues: Smoke Alarm,Fault?! Zone 10 Door chime not working? And how to do I change user codes? I've checked instructions but unable to find any information, thanks. Edited January 19, 2019 by Carlos12 Quote Link to comment Share on other sites More sharing options...
Carlos12 Posted January 19, 2019 Author Share Posted January 19, 2019 Everything is functional apart from the door chime. I've changed the settings on the keypad, to OFF and back ON, it makes the sound - but when the sensors move theres no sound?! What could be the explanation for this? I really appreciate your help, every days a school day! Thanks so much, my neighbour will be so chuffed it's fixed Quote Link to comment Share on other sites More sharing options...
