Sirenblinky Posted October 21, 2018 Share Posted October 21, 2018 Good morning. I have managed to hard wire the above kit. However if I put the Deltabell in to tamper triggering the microswitch the bell sounds and strobe works but no warning is displayed on the panel. Is this normal? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42461-pyronics-deltabell-e-not-showing-a-tamper-warning-on-pyronics-enforcer-panel-when-in-tamper/ Share on other sites More sharing options...
sixwheeledbeast Posted October 21, 2018 Share Posted October 21, 2018 No. The tamper must not connected to the panel correctly. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42461-pyronics-deltabell-e-not-showing-a-tamper-warning-on-pyronics-enforcer-panel-when-in-tamper/#findComment-480122 Share on other sites More sharing options...
al-yeti Posted October 21, 2018 Share Posted October 21, 2018 5 hours ago, Sirenblinky said: Good morning. I have managed to hard wire the above kit. However if I put the Deltabell in to tamper triggering the microswitch the bell sounds and strobe works but no warning is displayed on the panel. Is this normal? Did you programme the zone ? As tamper? Is correct resistor setting selected if needed Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42461-pyronics-deltabell-e-not-showing-a-tamper-warning-on-pyronics-enforcer-panel-when-in-tamper/#findComment-480132 Share on other sites More sharing options...
Sirenblinky Posted October 21, 2018 Author Share Posted October 21, 2018 Yes set input 33 to tamper on panel and wire from T Deltabell to Z33 in panel used 2k2 resistor from T in Deltabell linked to 12v - in Deltabell Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42461-pyronics-deltabell-e-not-showing-a-tamper-warning-on-pyronics-enforcer-panel-when-in-tamper/#findComment-480139 Share on other sites More sharing options...
al-yeti Posted October 22, 2018 Share Posted October 22, 2018 11 hours ago, Sirenblinky said: Yes set input 33 to tamper on panel and wire from T Deltabell to Z33 in panel used 2k2 resistor from T in Deltabell linked to 12v - in Deltabell I meant programming of resistance if needed Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42461-pyronics-deltabell-e-not-showing-a-tamper-warning-on-pyronics-enforcer-panel-when-in-tamper/#findComment-480143 Share on other sites More sharing options...
Sirenblinky Posted October 22, 2018 Author Share Posted October 22, 2018 Hi 4 hours ago, al-yeti said: I meant programming of resistance if needed Hi thanks for responding. I think I have got the wrong resistor in the bell it's a 4k7 I will change it for a 2k2. Will having the wrong resistor connected give me the issue I am having is it that critical? Don't no anything about resistors Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42461-pyronics-deltabell-e-not-showing-a-tamper-warning-on-pyronics-enforcer-panel-when-in-tamper/#findComment-480149 Share on other sites More sharing options...
al-yeti Posted October 22, 2018 Share Posted October 22, 2018 1 hour ago, Sirenblinky said: Hi Hi thanks for responding. I think I have got the wrong resistor in the bell it's a 4k7 I will change it for a 2k2. Will having the wrong resistor connected give me the issue I am having is it that critical? Don't no anything about resistors Change the resistor setting in the menu your missing that bit I don't really do these panels but last time I did that's all I had to do , the delta E is it a grade 3 bell you got? Or is it a delta plus? The tamper setting won't work correctly if you don't do the menu option resistor setting , check in the manual Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42461-pyronics-deltabell-e-not-showing-a-tamper-warning-on-pyronics-enforcer-panel-when-in-tamper/#findComment-480155 Share on other sites More sharing options...
Sirenblinky Posted October 22, 2018 Author Share Posted October 22, 2018 Ok thanks it's a class 2 though I not sure what that means probably to do with home insurance.its not a light box model Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42461-pyronics-deltabell-e-not-showing-a-tamper-warning-on-pyronics-enforcer-panel-when-in-tamper/#findComment-480156 Share on other sites More sharing options...
al-yeti Posted October 22, 2018 Share Posted October 22, 2018 1 hour ago, Sirenblinky said: Ok thanks it's a class 2 though I not sure what that means probably to do with home insurance.its not a light box model Ok that's cool , just set the right resistance in theenu options for 2k2 and it should sort the problem , failing that take pictures of both ends and I can take look The alarm monkies may correct me at some point , they busy scratching there heads at moment , all good Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42461-pyronics-deltabell-e-not-showing-a-tamper-warning-on-pyronics-enforcer-panel-when-in-tamper/#findComment-480159 Share on other sites More sharing options...
