September 28, 20188 yr comment_479589 Hello, I’m new to the site, installed my Agility system about 4 or 5 years ago and just recently got broken into, anti snap locks now fitted!!! i have just added the gsm module so I can be texted when the alarm goes off but i can’t find where I set which number it should call (my number), it’s all working as I can text the sim and set/unset the alarm but that’s not really why I got it. I have a feeling it under the follow me menu but when I try going into the menu it displays “Not Available”, anyone got any suggestions before I contact Risco tech help and make myself look a fool? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 28, 20188 yr comment_479596 3 hours ago, SeanT said: Hello, I’m new to the site, installed my Agility system about 4 or 5 years ago and just recently got broken into, anti snap locks now fitted!!! i have just added the gsm module so I can be texted when the alarm goes off but i can’t find where I set which number it should call (my number), it’s all working as I can text the sim and set/unset the alarm but that’s not really why I got it. I have a feeling it under the follow me menu but when I try going into the menu it displays “Not Available”, anyone got any suggestions before I contact Risco tech help and make myself look a fool? Thought the GSM module didn't call only text? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/#findComment-479596 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 30, 20188 yr Author comment_479600 It does only text but it needs a number to send the text to, I can’t find where I set this number which would be my mobile number Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/#findComment-479600 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 30, 20188 yr Author comment_479602 Managed to enable follow me which had opened up a number of menus but still can’t find where I set the follow me phone number which I assume is the number the agility calls to send the sms to Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/#findComment-479602 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 1, 20188 yr comment_479610 Probably TAP server? If so not worth setting up IMO. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/#findComment-479610 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 1, 20188 yr Author comment_479611 Got it sorted, it’s in the user Manual rather than the engineer Manual, just in case anyone else has the problem this is how it’s done: You send the following text to the sim in your alarm. code FMPHONE n NEW number code is the user code for arming alarm. n is the follow me number, I used 1. number is the number you want texting. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/#findComment-479611 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 20, 20188 yr comment_480079 On 01/10/2018 at 10:04, SeanT said: Got it sorted, it’s in the user Manual rather than the engineer Manual, just in case anyone else has the problem this is how it’s done: You send the following text to the sim in your alarm. code FMPHONE n NEW number code is the user code for arming alarm. n is the follow me number, I used 1. number is the number you want texting. That's great to know - I just installed a GSM module too. Waiting for my giffgaff sim to arrive. What SIM do you use? Also can you add multiple Follow Mes for the text e.g: code FMPHONE n NEW number 1234 FMPHONE 1 NEW 07123456789 (FOR ME THE GRAND MASTER) 4321 FMPHONE 2 NEW 07912345678 (FOR USER 2 - THE WIFES PIN) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/#findComment-480079 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 20, 20188 yr comment_480099 On 30/09/2018 at 18:06, SeanT said: Managed to enable follow me which had opened up a number of menus but still can’t find where I set the follow me phone number which I assume is the number the agility calls to send the sms to Hi mate, I’m getting the same message - not available. How did you enable the follow me? I’m still waiting to install my sim. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/#findComment-480099 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 20, 20188 yr Author comment_480102 4 hours ago, MaxX said: That's great to know - I just installed a GSM module too. Waiting for my giffgaff sim to arrive. What SIM do you use? Also can you add multiple Follow Mes for the text e.g: code FMPHONE n NEW number 1234 FMPHONE 1 NEW 07123456789 (FOR ME THE GRAND MASTER) 4321 FMPHONE 2 NEW 07912345678 (FOR USER 2 - THE WIFES PIN) Yes you can, I used m2m (machine 2 machine) they ensure you sim will never expire 23 minutes ago, MaxX said: Hi mate, I’m getting the same message - not available. How did you enable the follow me? I’m still waiting to install my sim. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/#findComment-480102 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 20, 20188 yr Author comment_480103 ok, I think you need to go into engineers menu using * 0132 Then go into programming # Then system # then controls # the communications # Fm enable half unlock symbol (y/n) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/#findComment-480103 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
