Hi
I have a Honeywell Accenta/optima ADE Gen4 installed in my home. The system was already installed when we moved in.
I have the bell on the outside of of the garage with 1 display panel and Accenta mini panel on the wall inside the garage.
The 2nd display panel is under the stairs in the house, with a sonit 1 speaker above.
Last night the alarm sounded twice, about 2 hours apart. Each time I checked around the house, nothing to report. I didn't think of checking the log until this morning.
The alarm usually sounds when we have a brief power cut, so before I checked the log, I tried turning the power off and on at the fuse box to double check that the alarm does sound with mains power off. The alarm sounded, so I went to reset it, but the display on each panel is lit but displaying a line of black blocks. While I can reset the alarm and perform other functions on the display panel, I can't see any feedback displayed, other than the blocks in the photo.
I tried turning the mains power off and on again, with the same result. The display was working fine before the first time I tried turning the mains off.
The red power light is lit on the Accenta mini panel in the garage, although it is quite dim, it is on.
I have read other threads on similar problems, but nt this exact one.
Any ideas would be much appreciated.
Thanks
D
Edited by misterm
Thanks for the reply.
It was installed about 4 years ago, just before we moved in.
Would the dim light on the mini panel suggest a faulty battery?
Would my passcode being the same and the alarm sounding with mains power off mean the battery is ok?
D
The battery is ready for changing @ 4 years,  the light on the main control may be dim by default.
The only way to test the battery would be a discharge test.
Thanks Norman
I think I'll just go ahead and order a new battery.
I have no means of charging it pre installation, would I be safe just plonking the new battery in? Or is there anything I need to consider before hand?
D
  • 2 years later...
On 31/08/2018 at 09:21, misterm said:
Hi
Thanks
D
Did you have any joy fixing this as I have the same issues after a power cut.no numbers just black boxes
as its a 2 yr old + plus topic id create a new one based on your circumstances
  • 1 year later...
Have you fix this issue as I have the same? I see yours was a year old so just hoping you might be able to help me!
Hi
Thanks
D
Panel low voltage
Register a new account
Sign in
