3 hours ago, sixwheeledbeast said:
The service is because it's been a non-maintained system so checks would need to be done, part of this would be to diagnose the fault and get the system operational.
Having a service and repair is more cost effective in the long run than someone resetting your PA for the cost of a call out.
If your alarm system sounds when isolating the power it clearly shows the system hasn't been serviced in a good while and the battery will be dead.
Expect an incoming approved company to recommend a panel upgrade and service contract too.
Top info, cheers for that! Hopefully resetting the PA will do it, failing that I'll have a look for an engineer to fix/replace it. Hopefully it won't cost too much!
Cheers all, for the info :).
Hope PA button dont snap when you turn that key lol
Register a new account
Sign in
