Pyronix Enforcer comms issue
I just upgraded my old Castle Caretech panel and 3 zems, to a Pyronix Enforcer and 4 new zems. The extra Zem is ncessary at the side of the new panel because the new panel only has 2 inputs. I am using all the old sensors and cabling as they worked perfectly previously.  I am finding that each time i arm the system,  three comms errors appear in the log during the 5 minutes after the alarm is set. No further errors are ever logged while the alarm is set, and it has never falsely triggered. I've got the phone app working nicely and I am pleased with the information it gives me.
So, trying to troubleshoot this....The documentation for my old system recommended that a terminator resistor should be fitted across pins C & D on the last device on the RS485 chain. I have not seen any mention of this in the Enforcer documentation. I have tried  including and omitting the resistor on the final zem. The same 3 error are logged each time I arm the system.
I'm powering all 4 Zems from the Enforcer panel. The documentation seems to be saying that this is OK.
Can anyone suggest how else I can troubleshoot this please?
Thanks,
Ian
  • Replies 71
  • Views 46.1k
  • 3 attempts at communicating every time the the system is open or closed...   Digi programmed ?   so-   4 wired zems on an enforcer + wired bell(s) ?   all
  • +150mA for the controls ?   + bell, modern low current one 60mA in day   call it 500ma for easy math ?   lets call the 2200mA panel battery 2.5A for easy math?
  • I did get a 55sec BB off at 11.59pm last night and a 3 minute off at 9.17am but the alarm didn't Comm fault which is okay with me.
Have you disconnected one zem at a time to see if one removes the fault
I suppose you don't have any detailed info on the error?
I haven't disconnected any Zems yet. Would I lose the configuration of the zones on the Zem if I did?
When I press 'C' to get more info on each error event, It displays 'Control Panel'. I don't know how to get more info.
I just noticed also that I'm getting 3 comm errors in the 5 minutes after disarming the panel. For instance, here are the log entries from when I arrived home this evening:
17:55:19 Entry time start - Full Set Front Door
17:55:25 Unset - Main keys Full set
17:57: 06 Comm Fault - Control Panel
17:57:13 Comm Restored - Control Panel
17:59:02 Comm Fault - Control Panel
17:59:06 Comm Restored -Control Panel
18:01:43 Comm Fault - Control Panel
18:01:47 Comm restored - Control Panel
I find it strange that there are always 3 sets of entries, and that they are always in the 5 minutes after arming/disarming the panel, and that there are never any further comm errors until after I have armed/disarmed the panel again.
I don't really know this panel , you have put on exit wireless that might be causing this?
Not sure about the settings just talking general blag if you get me ......
Or perhaps you have created areas or groups or whatever they are on the panel more blag
Digi programmed ?
so-
+ wired bell(s) ?
all powered off the controls ?
Yes maybe Digi but I thought enforcer can't have both , you have to remove one card to fit other
This is a 100% wired system. Nothing is wireless. Every zone is in Area A, and the downstairs zones are also in Area B. Intelligent set is configured to set Area A if I exit via the front door. Otherwise it sets Area B (downstairs only). I haven't reconnected the (single) bell yet though. (it was raining on Monday when I finished connecting everything else. So i didn't want to get my ladders wet). Even when the bell is reconnected, I wouldn't expect it to draw more than a few miiliamps.
I don't know what digi programmed is. I configured everything via the control panel if that helps. The only communication card is the wifi card which came with the panel.
So is something polling and failing to connect
Check all your network settings
PS don't forget bell needs to be in scb mode and if it doesn't have it , get one that does
Edited by al-yeti
I would have thought that the network settings were not part of this problem. The panel is just above my wireless router, so it gets excellent signal strength. It has a valid IP address and connects to the Pyronix server without a problem. I can always log in from the app on my iPhone, although I probably never connected during the brief spells during which the comms are down.
The error is logged as a comms error. To me that means RS485. Two of the zems are side by side in my loft. I still have the 12V lead acid battery from my old panel. I will try using it to power those zems temporarily, and see if it makes a difference.
Yes my Bell is in SCB mode. I will reconnect it tomorrow weather permitting.
Logs from this morning as I left the house.....
7:18:31 Exit started by Main Keys Full set
7:18:40 Final Set - Main Keys full set
7:20:24 Comm Fault - Control Panel
7:20:28 Comm Restore - Control Panel
7:23:03 Comm Fault - Control Panel
7:23:10 Comm Restored - Control Panel
7:24:58 Comm Fault - Control Panel
7:25:03 Comm Restored - Control Panel
You try power cycling?
