Texecom Premier Elite AMDT
Hi guys its been a while since my last confession but it seems I could do with some help, I dont see much intruder these days.
 I was given one of these Texecom Premier Elite AMDT  to replace a defective Honeywell DT, the existing DT is connected to a Menvier panel.
Am I right in thinking that these detectors can only be used in a EOL situation? I couldnt see how you could connect them as just an old traditional 2 loop alarm and tamper circuit.
On Meniver the resistors would be the same as Texecom. Jumpers all off for DP connections.
I thought you'd shacked up with a rich bird ?
They dont come much richer, she is married to me now ;-)
Blonde, Brown or Black...
What colour is her guide dog ?
I witnessed that and it was a lovely do
Dont connect the AM up
Yeah the resistors bit I sussed but they come on a little board that is fitted to the PCB, there was no jumpers.
It was Pete, would do it all again if I could guarantee the same perfect day.
You dont get the option of not connecting the AM up it only has 2 connections for the loop
Sort after breed me mate, all women love a bit of Geordie :o
Ah, that type has different modules for the resistor values, I don't believe there is a DP board option as it's aimed as a Grade 3 product.
If you decide to use it best to wire your Menvier for EOL, switch DIP 1 on to and a link into set to disable AM.
Even then detector has a possibility of throwing a 4K4 with a "detector fault", not sure what a Menvier would do with that resistance (either nothing or alarm condition if on threshold).
Suppose it depends which panel
