Siemens SPC wireless zones
Thanks everyone. Turns out there was a jumper inside that needed to be linked out. All sorted now
  • Replies 23
  • Views 4.7k
  • The only time I see the SPC/Signet wireless devices go discon is either when the tamper is open or the battery is removed. Apart from that I'd say faulty sensor
  • xpertalarms
    xpertalarms
Yep. Optional off wall tamper. Not sure why the prev co hadn't linked it out as there's no off wall tamper on it!:huh:
Wireless detector without off the wall tamper does not comply to regs, just saying :blink:
amealing@texe.com
Head of Industry Affairs
Visit Our Website
Texecom
#xpertalarms
You mean on the door contact? Yes, you can disable the rear tamper, but the tamper switch it is always 'on it' - presumably just not fitted correctly to the wall?
You sure it's not a small micro sized switch you didn't notice , sometimes pushed in by the plastics
And because you screwed it in bent it doesn't close (just kidding)
Edited by al-yeti
Here's the back with the tamper...
Edited by datadiffusion
...in the wall?
