October 18, 20179 yr comment_469825 Hi I have Menvier Ts2500 that keeps alarming after battery removed. Any ideas why? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41651-ts2500/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 18, 20179 yr comment_469828 Replace the battery? Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41651-ts2500/#findComment-469828 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 18, 20179 yr Author comment_469830 Hi . It is only when I remove the battery that this fault occurs? Keypad will scroll through random messages as well! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41651-ts2500/#findComment-469830 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 18, 20179 yr comment_469832 why are you removing the battery ? Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41651-ts2500/#findComment-469832 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 18, 20179 yr Author comment_469834 Hi . Just for testing . Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41651-ts2500/#findComment-469834 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 18, 20179 yr comment_469839 Have you powered the whole system down and back up? i have done this before to clear network errors.sounds like you may have some interference or a ****** panel, have you tested for induced AC and checked the cable insulation? please note though, not all TS 2500 come back to life from a full power down lucky for me, mine are immortal Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41651-ts2500/#findComment-469839 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 18, 20179 yr Author comment_469841 Thanks for your help! I think it is the panel! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41651-ts2500/#findComment-469841 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 18, 20179 yr comment_469844 The psu was a major problem on these does not like to keep 17 ah battery fully charged. it uses the battery like a giant smoother capacitor if the panel powered any thing other than the sas or redcare it pushed it to its limit so had to always power network and detectors from separate psu Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41651-ts2500/#findComment-469844 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 18, 20179 yr comment_469846 Sounds like the PSU/transformer is failing or has been overloaded. Had this with 2500 and 900's Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41651-ts2500/#findComment-469846 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 18, 20179 yr comment_469850 9 hours ago, BeechStu said: Hi . Just for testing . how are you testing the battery ? Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41651-ts2500/#findComment-469850 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
