Accenta G3
Regarding a Accenta G3..When altering the three programming suites 1,2 & 3 how do you select zone type immediate for a sensor? Say I want zone 4 to have a zone type of immediate how do I change this?
I know if i need i can turn on entry deviate in Flag B menu.
Their system was set up so that ZONE 1 WAS TIMED ZONE 2 WAS TIME INHIBIT ZONE 3 WAS IMMEDIATE... zone 4 is the E/E pit by the front door but under Program 1 zones 3-8 to set are set as immediate??? Can the function be changed... or would i just have to swap the zones in the panel (so that zone 4 e/e would now be zone 2 timed inhibit)
thanks gents
Edited by Litch90
Oh you wag. But, is there?
you could swap the circuits, but why is cct 4 cct 2 as it should be?
8 hours ago, al-yeti said:
Is there any possibility you can scrap the panel?
might very well do.. right nightmare trying to programme only of LED's
t
They had zone 4 in the hallway acting as a Exit pir...  but of course zone 4 is seen as immediate by the panel is it not? So on these older G3's I'm guessing you can't change the zone type manually?
On 18/06/2017 at 7:57 AM, Litch90 said:
t
On the G3's you can change any zone type. Easier with the LCD keypad.
