Texecom Premier Elite 24 - Full Set
Hello Everybody,
I'm hoping you can help me with what is (hopefully) a relatively simple fix;
I upgraded the firmware on my premier elite 24 panel from 2.(something i cant rememeber) to 3.2.
Since doing so when i press the area button on my control pad in the hall the system goes to part arm 2,
The system is set into 2 areas;
Area A = Ground Floor and Garage
Area B = First Floor
The control pad in the hall is set to Area A&B but I havent got the "use keypad areas" box checked in wintex, I tried it and it made no difference.
The second control pad is in the second floor landing, This is set to area a only, the idea being that I set the alarm from the second floor pad at bed time and we can roam the first and second floors (no sensors on second floor) and then either dis arm from second floor in the morning or go down stairs and the hallway sensor will start the entry timer.
The Parts arms are as follows;
Part arm 1 - Doors and Garage
Part Arm 2 - Bedtime - Seperate to only activing area A from second floor pad
Part Arm 3 - Garage Only
So before i updated the firmware it all worked beutifully, I press area in the hallway when leaving the house and the whole house was armed, and i pressed area on the second floor pad at night and only the grond floor and garage was armed. Like i say though, when i press area on the ground floor pad now it automatically goe's to part arm 2.
I even change the configurations on part arm 2 so it was the garage only setting and part 3 was the bedtime incase something in the zone settings was confliciting but it made no difference, even with the garage as part 2 when i press area it still auto's to part 2.
HELP PLEASE!!!!!!
  • Replies 25
  • Views 12.1k
Hi Dale,
No I haven't defaulted the panel, if I default it can I then restore from a Wintex backup?
Thanks
Yes but take screenshots of each page first just in case!
You often get weird errors like this when you don't default nvm especially on a major update.
You MUST default the panel when moving between major versions of firmware.
You can restore it if you took a backup before flashing.
The current panel config is damaged so do NOT take a backup now to replace your old one.
If in doubt default and start again.
Evening Gents,
Thank you for the comments, I've defaulted the panel and restored from a previous backup. All is good, and luckily it was simple fix.
It took me a little while to get the ComIP pushing notifications to the mobile app again, it's helpful that there's nothing in the ComIP manual about setting Config 2 to use COM 1in the ARC settings!!!
The only thing is that when I press area on the second floor Pad once armed the display flashes between the part arm text ( ** PART ARM**) and Area A. I'm not sure whether it should be doing this as technically it's not part armed?
Thanks for your help so far.
You must have an older stock of the ComIP (and therefore manual) as the Use Com Port option was only introduced in latter firmware.
Part Arm banner will indicate that the system is part set so maybe you still have an issue if you are definitely full setting.
I'm full setting Area A and excluding Area B.
Do you have any ideas what could be causing it?
Thanks
Sounds like you need may need to use Areas and Part Arms in a different way.
I don't know the layout of the house and keypads or what you need to arm.
I would have House and Garage Areas, with a Part Set for Bedtime.
When only arming some of the areas it shows the part arm text as only part of the entire system is armed. A feature that annoys me.
However as said you really should have the house as area a and the garage as area b. Then use part arms within area a.  Also means you can then have the garage armed throughout the day and auto arm it etc
Edited by installer_dale
