Euro46 control panel
  • Replies 32
  • Views 6.8k
Ar ok so the app to work dont  need WiFi or LAN can run off the GPRS as well ? You get full use of app with GPRS ?
49 minutes ago, petrolhead said:
App bersion will sms as well as push notification if it has a digi gprs.
Can't say I have tried but in manual for gprs
IMPORTANT NOTE: The DIGI-GPRS+SIM can only be used on HomeControl+ V2.0 and V2.1 control panels. Please see your control panel user, programming and installation manuals for further information. SMS functionality is not currently supported.
I will email pyronix and ask.
Also can't find anywhere that sell.the gprs module and the SIM . As i have herd pyronix do a sim.
It works on one i fitted a while back, not tried it since. Very early firmware one.
Ok great.
So you by the app version panel but you still need to by the goes module so why doesn't the panel come with the module and what's the difference with the app panel compared to the standard euro 46 panel as i thought you would of got the module with the app version and that was the difference but it isn't.
Thanks
Mark
30 minutes ago, Mark Rider said:
Ok great.
Thanks
Mark
Probably because there's only so many modules you can fit inside it, so why sell you something you dont need ,and make it optional
Edited by al-yeti
No you are correct, but it has to be a third party SIM card & not a CSL one.
I have only installed the CSL ones.
So there you go Mark, buy the app version panel and get the GPRS module with a high street data SIM card.
I've registered with the Pyronix Cloud as Administrator. Does registering as an installer give more options?
Does the gprs sim card come in the gprs card as a set?
