Pyronix Homecontrol+ vs Visonic Powermax vs Texecom
I'll go through the instructions again - I've gone through Wintex and then checked through the panel. Only thing I can't guess is the gateway... Iv4 gateway suggests end .0 and LAN gateway .255 at the end... I've tried both to no avail. Will also look into the port scanner
I gather arc is entirely different to the app? Will I likely need it if the new app lives up to expectation?
  • Replies 312
  • Views 173k
It's not released but I believe the new app will need no setup at the panel end if you have setup the panel correctly.
The ARC lines are where you put the push server numbers as listed in your COM-IP instruction book.
https://en.wikipedia.org/wiki/Default_gateway
Right, I'll be setting the router up tonight for DNS... And have signed up to no-ip to cover that aspect. Hopefully this will get me fully, remotely live
If you use the push feature (I.E setup ARC settings etc) the Texecom's server will do the DDNS for the app.
So that would negate using the Ddns address in the ip setting on the app?
I've set up the arc, created the account, updated the panel, turned digi on, set poll ip... Test call won't initialise though
Edited by 1animal1
Follow the instruction in the manual, if test call fails try changing polling time to 1 min, wait 10 mins then see if this has changed to 15.
If yes, test should work, if no something is not setup correctly.
So today's state of play. We have notifications going to my mobile but the app is still showing purple when operating remotely. I've double, triple checked everything... It has come up with a warning though saying the app isn't encrypted, and there's two encryption codes on the udl page of the app.... Cannot find anything about where they go on the panel though as suggested
