Resistance reading on each zone
I do own multimeter... I'm just asking because it's not working for me. I was told to twist to spare cables in each device together and measure resistance on those two cables in panel site. But each pir I have measured shows me 0 so clearly there is something wrong. The reason I ask was just simply to make sure that I'm doing it right.
  • Replies 38
  • Views 8.1k
  • datadiffusion
    datadiffusion
    20 years ago might have had a chance, now the distinction between and alarm and a 'home automation' system would keep the courts busy for years...   The ultimate test of 'is it an alarm you'
  • Surely one of your team of experienced cctv specialists who do insurance approved installations would be best placed to explain this stuff to you face to face?
move dial to diode test (between 2ac & hFE)
touch probe togther & does it buzz?
0 all the time 0. I have just checked on resistor and showed 0 as well.  Obviously on kilo ohms I checked. So I just think meter is faulty?
So with the meter set to 200 ohms you get 0 with the leads shorted together, what about without the lead touching, what does it display....
