hd down rf modulator
redsun
4 hours ago, sixwheeledbeast said:
Granny Goggins is most likely listening to The Archers?
But yes I have been in that situation explaining how to switch HDMI channels for the sake of the cost of a separate monitor.
I feel sorry for you, imagine it either doesn't get used or no end of callbacks?
Ok thanks for that , I'll take your advice and make the purchase.
i did buy a 10mtr and 15mtr hdmi lead from cpc to connect to 2 TVs but they didn't work. No picture. I assume they were not of high enough quality?
13 hours ago, redsun said:
As petrolhead says and also the listing -> "This cable functions as a signal transmitter, but NOT a signal converter."
You need to convert to a composite signal to use the existing modulator.
They probably doesn't get used, some are for playback purposes only anyway.
Yes. Usually either anyiference or vision, depends what they have on the shelf ag solutions group. If i'm stacking more than 2 devices in the rf chain i'll use a combiner and a few variable attenuators and use my spectrum analyser to tweak until all the muxes have a similar signal level at the faceplates.
Safest bet is one of the wee 0-25db variable attenuators then you can tune to your exact requirements. All being well you would dial it back until the new modulated mux is at a similar level to the muxes from the aerial, shoot for around 65dbmv at the most remote faceplate.
  • 4 weeks later...
Hi all,
im struggling with this hd modulator.
im trying to get hdmi out of Dvr onto all TVs.
could someone tell me if this is wired correctly.the horizontal coax to combiner is the aerial. The attenuator is 20db
ive had Cctv up once but no channels now can't get it again.
what channel would you recommend? Between 21-69 then what programme number?
The user instructions for this technomate are pants
any help appreciated
Edited by redsun
Typo
