engr
  • Replies 24
  • Views 4.9k
  • Created
  • Last Reply
cool, 1st TSI top tip..... beware of Nigerian scammers ;)
Not all Nigerians are scammers Dave, you cant go round stereotyping people by the country they live in
Hi and welcome coituma, what would you like to know about the UK's security industry
cause I can, I even drill it down to county,
A big hi6 to AG & the cornwell massive :D
Thanks for your understanding, Am interested in installation of CCTV. I recently ran into some problems while installing, and am looking for solutions for it.
1. I have 10 cameras installed in a location, 4 channel cam is always burning in spite  that I used power box. It will work very well, but once I short down to come back next day on putting it on the 4 cameras will not come again. Please what could be the possible problems? And solutions.
2. In another location with 16 cam, 2 out of it keep tripping off without showing video loss and when I check the cable with hand monitor it shows the video. Please how can I resolve this?
what system is it?
have you tried swapping inputs?
Thanks
Is DVR H.264 and yes I have swap input even to an extent of connecting it another DVR there
Whats the distance between the cameras and the dvrs? Are the cameras powered locally or at the dvr? What type of cable are you using Shotgun or cat 5?
The distance between camera and DVR is about 145 meters.
The camera is powered with CCTV power box which contains fuses for every channel.
I use RG-59 with power for about 50 meters, at that point I fit in the power box to power the cameras and the rest distance I used RG-6 coaxial cable to DVR. Thanks
So the power is about 100 meters away the coax is 145 meters Have you checked the voltage at the camera?
