Guest SimonR Posted August 18, 2003 Share Posted August 18, 2003 Hi, Like a previous message I have read, I have just moved into a new house and the previous owners have not left any documents about the Alarm. Could you please send me a pdf of the user manual for an Optima XM6? Thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/393-optima-xm6/ Share on other sites More sharing options...
Service Engineer Posted August 18, 2003 Share Posted August 18, 2003 Ive attached the user instructions to this post. Optima_XM_user_Guide.pdf ........................................................ Dave Partridge (Romec Service Engineer) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/393-optima-xm6/#findComment-1863 Share on other sites More sharing options...
Guest colinchinn Posted November 1, 2003 Share Posted November 1, 2003 many thanks from me also for this, I have been trying to get hold of a manual for the optima xm alarm ever since we moved into the house. best wishes Colin Link to comment https://www.thesecurityinstaller.co.uk/community/topic/393-optima-xm6/#findComment-4083 Share on other sites More sharing options...
Guest ukchik33 Posted November 3, 2005 Share Posted November 3, 2005 Hi, Like a previous message I have read, I have just moved into a new house and the previous owners have not left any documents about the Alarm.Could you please send me a pdf of the user manual for an Optima XM6? Thanks Hi I'm looking for the user manual for the above. Not got previous pin code from previous owner's though. Can you help please? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/393-optima-xm6/#findComment-74204 Share on other sites More sharing options...
Service Engineer Posted November 3, 2005 Share Posted November 3, 2005 This Better..? ........................................................ Dave Partridge (Romec Service Engineer) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/393-optima-xm6/#findComment-74235 Share on other sites More sharing options...
Guest bladecentre Posted January 25, 2006 Share Posted January 25, 2006 Hello , Sorry to be a pain, but i too would like a copy of the user Guide for the OPTIMA xm6. I Have had an installer check the system after it kept going off. But recently the alarm now goes off as soon as you open the entry Door. So i am hoping its just the timers that need adjusting. I dont want to spend another 45 quid for an engineer to come round when i could do it myself. He has replaced motherboard and battery. Thanks for your help guys... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/393-optima-xm6/#findComment-84219 Share on other sites More sharing options...
Adi Posted January 25, 2006 Share Posted January 25, 2006 He should have left you with a user guide or posted you one. As for timers they are engineer programmable and im sorry but we do not give them out for security reasons. If he has not set your system up correctly get him back, youve paid for the job to be done. Someone will probably post a link for the user manual soon. I really can't be ar**** with it anymore. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/393-optima-xm6/#findComment-84221 Share on other sites More sharing options...
morph Posted January 25, 2006 Share Posted January 25, 2006 User manual is attached further up the topic. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/393-optima-xm6/#findComment-84222 Share on other sites More sharing options...
Guest Posted January 25, 2006 Share Posted January 25, 2006 If the system was working correctly then recently decided not to it's not the engineer at fault. I believe it will be a relatively simple fix and a call to your installer will be required to replace the offending part. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/393-optima-xm6/#findComment-84248 Share on other sites More sharing options...
Guest bladecentre Posted January 27, 2006 Share Posted January 27, 2006 well did try to download the manual from above but says the link has been removed.. I will call the engineer and see what he says as well as testing to see if its the contact. Thanks for the quick replies...just hope the engineer is as quick at fixing it... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/393-optima-xm6/#findComment-84524 Share on other sites More sharing options...
