Ax200 / 100 / 50
datadiffusion
You'll not have heard of them but a funny little outfit called Axxess makes obscure (but not in a closed protocol, f-off sort of way, more like you've not heard of them)
access control panels and I'm not sure if they are / were part of Cooper or not, as you could by as a Scanny or Axxess branded unit, as an AX50, 100 or 200.
Anyway, does anyone familiar with the Scantronic AX10 external prox know if it will work with said systems?
The fact it has an AX in the code and the scantronic instructions tell you to ignore some of the wires (buzzer, etc...) make me
think they are just standard units, and it's the scanny keypad end that's been altered to suit the data, not the other way around...
ta!
Link to comment
https://www.thesecurityinstaller.co.uk/community/topic/39248-ax200-100-50/
Share on other sites
No... not on this occasion.
http://www.axxessid.com/
Identical to Scanny AX200
Village hall with separate front and back readers hanging off one unit. Using swipe cards, system supports prox, which they want to change to.
Usual case that they won't even remotely comprehend changing it because Maureen knows how to use the management software since 1998....
Just wondering if the Scantronic AX10 was just a re-badged version of this - http://www.axxessid.com/Pguide/105-220.html
Having touched neither....
It would appear you can buy a tag 3rd party tag with works with scanny & the access axxessid stuff.
I'd say yes, I'd also guess they sell HID & it works with their kit too?
It seems to suggest the reader unit works in weigand but auto detects an ax host and changes to some sort of special protocol. So if the host is the same isnt clear, but, as you say if they deal in hid the controller must do wiegand too.
