Spyman48 Posted October 6, 2015 Share Posted October 6, 2015 Hi does anyone know how to if you can still get the old payg SIM cards for use in a GSM communicator the mobile networks all seem to do these bundle deals for say £10 but it expires after 30 days ! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39187-gsm-sim-cards/ Share on other sites More sharing options...
sixwheeledbeast Posted October 6, 2015 Share Posted October 6, 2015 All none contract SIM's will expire, you have to use them to stop them expiring. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39187-gsm-sim-cards/#findComment-431933 Share on other sites More sharing options...
Dick Posted October 6, 2015 Share Posted October 6, 2015 I think the expiry you refer to is the fact you put £10 on the sim and if you don't use it within the 30 days you lose the money not the use of the sim. You can still get PAYG sims and top up what you like (in £5 increments) but you don't need to keep topping it up until it has gone. Where security is concerned an automatic top up is worth having where the airtime provider will automatically add funds when your balance reaches a set minimum. I use Tesco Mobile who use 02 which has by far the best reception where I am. I have my balance set to top up £10 automatically when the amount drops to £10. A £10 top up actually costs £9 set up this way so texts work out even cheaper than the standard 4p a text. I use my automation several times a day and of course calls to the dialler are free should I wish to go that route. If I never used my dialler it is programmed to do a test text at least once a month to keep the sim active. This is easily managed online too so really isn't a fuss. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39187-gsm-sim-cards/#findComment-431942 Share on other sites More sharing options...
al-yeti Posted October 6, 2015 Share Posted October 6, 2015 What dialler are you using ? , normally has a daily or weekly alert to keep SIM going And too it up every 6months or so unless you got regular false alarms Cheaper just to get a virgin SIM £5 until July, monthly rolling, then I think it's goin up a bit But that's if you have sia sent via your dialler you need the contract SIM for that Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39187-gsm-sim-cards/#findComment-431943 Share on other sites More sharing options...
Dick Posted October 6, 2015 Share Posted October 6, 2015 You can't get any cheaper than 3.6p a text that is charged for use only and not on a rolling contract basis that you pay for regardless of use. Also, as far as alerts are concerned, no airtime provider shuts down a sim within a day or week through no use so why the unnecessary tests if you 'test' it yourself by using it several times a day or even a couple of times a month say? Your top up is directly dependant on use too. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39187-gsm-sim-cards/#findComment-431945 Share on other sites More sharing options...
Spyman48 Posted October 6, 2015 Author Share Posted October 6, 2015 That is what I meant about the SIM card with the bundle option , thanks I will look into the tesco O2 cards . I haven't decided on a gsm dialler yet what would you recommend Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39187-gsm-sim-cards/#findComment-431950 Share on other sites More sharing options...
Dick Posted October 6, 2015 Share Posted October 6, 2015 I have had no problem at all with a Pyronix V2 GSM dialler. It was that or the Menvier SD3 offered to me by my installer. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39187-gsm-sim-cards/#findComment-431955 Share on other sites More sharing options...
Spyman48 Posted October 6, 2015 Author Share Posted October 6, 2015 Thanks for your help Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39187-gsm-sim-cards/#findComment-431956 Share on other sites More sharing options...
abbz Posted October 6, 2015 Share Posted October 6, 2015 Look at Giff Gaff Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39187-gsm-sim-cards/#findComment-431957 Share on other sites More sharing options...
PSE Posted October 6, 2015 Share Posted October 6, 2015 ^^ Same here, GiffGaff is ok, but your to pup but select calls only. Don't buy an add on Your credit will last until it runs out, as long as a chargeable call or text is made within 3 months Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39187-gsm-sim-cards/#findComment-431958 Share on other sites More sharing options...
