Engineer Code For Menvier M-Series
  • Replies 43
  • Views 28.4k
Alarm subscribers....
As a rule of thumb if the incoming co. needs wet nursing by the out going co. so they can support the system you may find you picked the wrong people to look after your alarm ;)
can I borrow this?
we were asked to default an engineer code this week..
on a gardtec 595.. panel was unlocked....
new company couldn't default it.. we lost the maintenance because they were cheaper...
can I borrow this?
thats the correct way to do it,it could be a 2 zone panel or it could be a 200 zone panel,its not about the ability to crash and reprog or the cost
can I borrow this?
LOL, I've had people kicking off about "locked" 700l's
there will always be someone cheaper. its easy to be when you dont do the service visits and use single path ****
do you have a list of other co's engineer codes? most do
its a chase to to the bottom but you need to worry about stuff, those that dont will be gone, those that do will be affected by those that dont. ive seen a rise in digi air being the same as red gsm apparently
no i dont id always default so see no need
of course you do,why crash and reprog back to the way it was
default yes or code default. Not for free, but if they want to leave then then do
id rather default the lot but we dont just code
I was talking takeovers,you say you default panel and reprog,fine if a 2 bed semi but a large commercial with no paperwork you've lost 3yrs maintenance money just putting it back to the way it was
