dwdave Posted August 11, 2015 Author Share Posted August 11, 2015 Not sure if its of any help to those still reading but I have just copied off the users list and it had a couple of users in the system still. Im guessing that Mike & Claire no longer needed their system for some reason and that ties in with the paypal details. The zones list was clear though. 'till the next question ... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38920-panel-swap-classic-500-to-dimension-520c/page/5/#findComment-426902 Share on other sites More sharing options...
goncall Posted August 11, 2015 Share Posted August 11, 2015 Not sure if its of any help to those still reading but I have just copied off the users list and it had a couple of users in the system still. Im guessing that Mike & Claire no longer needed their system for some reason and that ties in with the paypal details. The zones list was clear though. really all the zones were still in and you only have 2 faults when coming out of eng mode Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38920-panel-swap-classic-500-to-dimension-520c/page/5/#findComment-426906 Share on other sites More sharing options...
dwdave Posted August 11, 2015 Author Share Posted August 11, 2015 No the zone list was clear - blank - default - INTRUDER and showed Tamper O/C - but I cleared them. I couldnt clear the LineFaults. 'till the next question ... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38920-panel-swap-classic-500-to-dimension-520c/page/5/#findComment-426909 Share on other sites More sharing options...
charlie6 Posted August 11, 2015 Share Posted August 11, 2015 So it could have been an ADT panel left at a property, which the owners had purchased.. in that case they have every right to sell it. But why sell it if it's working correctly ? Your car working OK..in that case I'll buy it ? Not working OK... sell asap..to someone else !! simple isn't it. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38920-panel-swap-classic-500-to-dimension-520c/page/5/#findComment-426910 Share on other sites More sharing options...
goncall Posted August 11, 2015 Share Posted August 11, 2015 No the zone list was clear - blank - default - INTRUDER and showed Tamper O/C - but I cleared them. I couldnt clear the LineFaults. so its a new defaulted panel with 2 users still progd in Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38920-panel-swap-classic-500-to-dimension-520c/page/5/#findComment-426915 Share on other sites More sharing options...
al-yeti Posted August 11, 2015 Share Posted August 11, 2015 Open case eBay, but you can't return panel though pending investigation of who owns it , maybe adt will say keep it just tell us who sold it to you Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38920-panel-swap-classic-500-to-dimension-520c/page/5/#findComment-426917 Share on other sites More sharing options...
dwdave Posted August 11, 2015 Author Share Posted August 11, 2015 or its a used panel that has been partially cleared? I would say that the box is a bit scruffy and I've been told it should have come with resistors etc but it didnt. It may point towards the panel being used ? 'till the next question ... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38920-panel-swap-classic-500-to-dimension-520c/page/5/#findComment-426922 Share on other sites More sharing options...
charlie6 Posted August 11, 2015 Share Posted August 11, 2015 Dave, please return this item via the ebay scheme and get a refund. Please do not buy from ebay unless you are absolutely familiar with the item you are purchasing. I mentioned above that contrary to popular opinion this panel is not stolen and the owner has every right to off load it, it is used and it is faulty. How much do you value your own time... £20 an hour...£40... you may well be enjoying your projects and I appreciate that, but in the end time is not on your side. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38920-panel-swap-classic-500-to-dimension-520c/page/5/#findComment-426925 Share on other sites More sharing options...
dwdave Posted August 12, 2015 Author Share Posted August 12, 2015 Do they have serial numbers? I'll contact ADT directly. 'till the next question ... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38920-panel-swap-classic-500-to-dimension-520c/page/5/#findComment-426934 Share on other sites More sharing options...
charlie6 Posted August 12, 2015 Share Posted August 12, 2015 I endorse all the previous posts made by the professionals, but allow me to pass on a 'ditty' from my own experiences as a jobbing troubleshooter... A installer takes one look at a panel, decides it's above him, sells the owner a new panel (one which he only has ever worked on)and suggests to the owner "..you can get a few quid for the old one on ebay"..Reading the previous posts it's as simple as that. I removed a panel recently and told them to bin the old one (not 'put it on ebay). There is not a bit of need to contact ADT, but that's your choice (what do you want ADT to tell you ?) When you return an item on ebay raise a complaint ticket..that usually gets the seller to sit up, but it's wiser to contact the seller first and tell them you are returning the item and require the return address..you don't have to give a reason..If you want one try using " not fit for purpose " (sale of goods act). Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38920-panel-swap-classic-500-to-dimension-520c/page/5/#findComment-426947 Share on other sites More sharing options...
