Gent Panel Clicking Every 60 Seconds
If you have it on a bench and the loop is made up of a couple of meters of cable, the loop may be to short and resistance of the loop is not enough for the panel.
good idea, ill try a resistor on the line
  • Replies 51
  • Views 32k
  • possible causes of a "chattering relay"   relocating a London relay to Scotland - relay is cold turn up heating until its acclimated ? relocating a Scottish relay to London - Irn-Bru & Battered
  • If you haven't got anything constructive to add to the discussion regarding the initial post then please don't bother, I can assure you I'm well aware of certain fire alarm engineers that frequent for
  • Pleased to see you are giving as good as you get there.   As for the fault I have never known any addressable fire panel do that with no faults but I cant see how you have it wired or what its wired
Nah nothing made any difference
When the loop is powered down this clicking doesn't happen
Edited by stelmo
As above what is that output programmed as?
When there is no power on the loop the loop isolaters don't operate, i dont know gent that well have the devices you are using go isolated bases ? is one wired wrong ?
www.nova-security.co.uk
www.nsiapproved.co.uk
This relay
These are internal relays that are not programmable, if I understand your question
Ive tried running it with just the isolated base only (no device attached) and only a single call point
I think ill bin it to be honest, I dont trust it with this clicking that its doing
the isolators are in the device not the base...
Well I did say it was the panel that was clicking
anyhow forget about it I'm bored looking at it
Thanks for the suggestions everyone that was kind enough to offer useful input.
Gent panels do click every so often its a quirk. Doesnt mean anything is wrong
After working on these panela for 10 plus years its become a white noise but its there lol
All comments in this post are my own views and do not necessarily reflect the views of my employer
