omegauk Posted August 2, 2014 Share Posted August 2, 2014 Hi, I am new to this site so first time post. I was called to a faulty panel, which I took out remembering to mark where the wiring went in the box. A replacement came this morning and I have fitted it carefully putting the wires in the right slots including the remote panel. I connected the battery with the tamper spring down and got nothing when I let the spring go causing a tamper. thinking the battery was flat I closed the tamper spring again and connected the power and I got the power light on, released the tamper spring and got nothing, no beeps no siren. can anyone please help put me right, Thanks David. Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted August 2, 2014 Share Posted August 2, 2014 (edited) What made you think the old panel was faulty? Are you sure it wasn't an external problem and you've just blown the fuses straight away? Edited August 2, 2014 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
omegauk Posted August 2, 2014 Author Share Posted August 2, 2014 the old one was light up but could not do anything with it, but when my son phoned me about it the alarms where sounding. I have checked the fused in the new box and they are fine Quote Link to comment Share on other sites More sharing options...
james.wilson Posted August 2, 2014 Share Posted August 2, 2014 I'd disconnect everything and use a short wire and just connect the keypad. Prove you haven't blown it up and go from there. You have basically just asked 'my car wont start what do you reckon it is?' Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
morph Posted August 2, 2014 Share Posted August 2, 2014 Hold old was the existing system and when did you last fit a new battery? Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted August 2, 2014 Share Posted August 2, 2014 Silly me assuming a battery replacement / test Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
Ronnie Posted August 2, 2014 Share Posted August 2, 2014 Hi, I am new to this site so first time post. I was called to a faulty panel, which I took out remembering to mark where the wiring went in the box. A replacement came this morning and I have fitted it carefully putting the wires in the right slots including the remote panel. I connected the battery with the tamper spring down and got nothing when I let the spring go causing a tamper. thinking the battery was flat I closed the tamper spring again and connected the power and I got the power light on, released the tamper spring and got nothing, no beeps no siren. can anyone please help put me right, Thanks David. I got plenty of advice but you won't like any of it. Quote Link to comment Share on other sites More sharing options...
omegauk Posted August 2, 2014 Author Share Posted August 2, 2014 As far as I know the alarm system was a new one put in by a electrician, they phoned him but he will not come back. it is a new battery, so I will check what you's have said. Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted August 2, 2014 Share Posted August 2, 2014 (edited) it is a new battery, It was a new battery, has it been drained flat for any reason? Edited August 2, 2014 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
omegauk Posted August 2, 2014 Author Share Posted August 2, 2014 when I first went to see it I was told the battery as just been taken off, so don't think so. but even when you connect to the mains and you get power light on, there is no sound from it at all even the tampers are not bridged.. and also the keypad does not light up or respond when the buttons are pressed. Quote Link to comment Share on other sites More sharing options...
