Onlyme Posted May 10, 2014 Share Posted May 10, 2014 Hi I need to replace the IR illuminator board on a Concept Pro 3026. It has two pole two pin plug fixings on the back. One says Power and the other says CDS I can find a 42 led ir illuminator board on the internet but not one with the TWO connections. Do you know where I can source one? Videcon aren't interested in helping me now that I am retired from the IT world Link to comment Share on other sites More sharing options...
norman Posted May 10, 2014 Share Posted May 10, 2014 Give Videcon a call Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
Amps Posted May 10, 2014 Share Posted May 10, 2014 Give Videcon a call Good advice! Link to comment Share on other sites More sharing options...
Onlyme Posted May 10, 2014 Author Share Posted May 10, 2014 Hi Thanks for the quick reply. I have called them and emailed them but they are not interested in helping someone who is retired and no longer in the trade Link to comment Share on other sites More sharing options...
norman Posted May 10, 2014 Share Posted May 10, 2014 Sorry, I missed that you had already called them. I'm surprised they won't help as they are normally very good. What's the fault with it? Could you look to repair? Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
Alarm Protection Posted May 10, 2014 Share Posted May 10, 2014 If no help you could buy a seperate IR and install under camera? ! Link to comment Share on other sites More sharing options...
Onlyme Posted May 12, 2014 Author Share Posted May 12, 2014 I bought some ir leds from Farnell but they turned out to be slightly bigger so "still at first base" Does anyone know which company makes these 3026 cameras. I presume the company will be in China. Link to comment Share on other sites More sharing options...
PeterJames Posted May 12, 2014 Share Posted May 12, 2014 Give Videcon a call LOL! If no help you could buy a seperate IR and install under camera? I think thats the easiest solution either that or a new camera and use the old one indoors Link to comment Share on other sites More sharing options...
cybergibbons Posted May 13, 2014 Share Posted May 13, 2014 The CDS connection goes to the little light sensor down at the bottom. How do you know that the fault is with the illuminator board and not the driver? I have a blog, some of which is about alarm security and reverse engineering:http://cybergibbons.com/ Link to comment Share on other sites More sharing options...
ian.cant Posted May 15, 2014 Share Posted May 15, 2014 Buy a spares or repair unit from ebay Link to comment Share on other sites More sharing options...
