Scantronic 9600 Faulty Keypad
bazzabear78
lol
  • 2 weeks later...
I tended to use a 1/2" x 6 self tapper countersunk screw as it didn't allow for movement espescially if it was mounted on an uneven surface which alot of installers find is the only place to mount keypads for some reason or other.
The shape of the backplate back tamper plastic wobbly bit (technical term) was shaped so that the screw remained in place and of course the tamper switch stayed closed unless someone tried to take the keypad off.
Practice in the morning, practice at night. Practice in the evening, until you get it right.
Only make sure you are practising in the right way at the right time for it.
  • 8 months later...
Sorry I never reported back on this. I (planned to) took the advice to go with the suggested replacement, but the alarm fitter disappeared off the face of the earth. Tried to get in touch with him for months with no luck.
Eventually, on a whim, I did something that I should have tried at the start. I hypothesised that the nature of the fault on the tamper switch might be that if it was pushed in more firmly, it would make a better contact. It's only returning to the thread that I see this:
I bet the bit of rolled up tape has fallen out
I think that's referring to the same idea, right? Anyway, I attached a sticky foam pad to the 'spur' which contacts the tamper switch, and it fixed the problem completely! That must have been back in around August.
Unfortunately, the issue has now reappeared. The pad was pushed in, so I added a fresh one, but no dice this time! Perhaps the switch has become that little bit more broken, and now even this trick won't work?
Anyway, I'm back to square one. Get someone to solder a new switch in place, of get the lot replaced. But I don't know a reputable alarm company in the area any more.
So, my questions to you good folk are:
Know a good fitter in the Macclesfield area?
Do you know whether its an open or closed circuit which sets off the tamper alarm? I'm thinking that just removing the button would fix the problem if it's a closed circuit that sets it off (although obviously I would no longer have a tamper alarm).
If I use the other keypad to put the system into engineer mode, then remove this keypad, get someone to fit another switch to it, then replace it, will it need to be reprogrammed?
That's a perfectly fair opinion :)
It's why I'm asking for advice on a good fitter in the area too. I'll see if I can find the websites you mention and see if they suggest anyone.
Unfortunately cant help with that as im in Cardiff but you should find them on the websites or maybe another member in here will be more local to you
