Corrie Tonight
Only what I saw and It didn't look good for us alarm companies tbh.
I don't use texecom bells but a local has a lot up!
lets hope he's hasn't got a packet of chweing gum in the next episode
  • Replies 103
  • Views 12.8k
Or a biro to pick open a D-lock....
or some of those special glasses that see the ir beams
I don't know James but it shows the Gary builder boy up his ladder, open bell which sounds for 2 seconds and he cuts cable that disables the bell.
I think texecom would go mental on this? I have never installed that bell but is the back up battery enclosed or can you just cut 4 wires that are free to cut?
Truth is with most bell boxes its only one wire you need to cut. Bring back the double skinned bell box i say!
I remember years ago one high street chain having a double skinned metal bell box that if drilled would create a short between the skins which would then tamper. There was also a pendulum type of switch inside to detect any movement. And was fixed with rawl bolts! Try disabling that fecker!!!
The red one?
you can still get the rapier with anti drill inner cover
I always wondered if they called it rapier to describe it's price point . . .
rape your ears I reckon,they are loud..
