datadiffusion Posted February 28, 2014 Share Posted February 28, 2014 (edited) Security Warehouse Eco 4 Channel Budget DVR Introduction Search for ‘4 Channel Analogue DVR’ on the internet and you’ll find more results ll not die and ironically you can now even get analogue DVRs in almost stylish white iMac mini type cases, aimed at home use; although they don’t feature things like RS485. It could be argued that ICs like the Sony Effio series or the 960H format have pushed analogue into realms of quality not envisaged 5 years ago when IP was seen as the best way forward, squeezing that extra bit of performance out of analogue video with little difference in cost for the camera, as opposed to IP where entry level is still at a high price and even using a PC or server as the DVR, good software is not free. Price though, is a major plus for the Security Warehouse Eco 4 channel DVR. Specially sourced, this entry level unit nevertheless offers a lot of features, and is a true professional grade product for the same price as a restaurant meal for two. But it turns out the low price doesn’t put it the same league as other (often dearer) dubious online offerings with brand names you’ve never heard of – far from it. This line of DVRs comes in 4, 8 and 16 channel varieties, and on all but the entry level 4 channel version you get hardwired alarm inputs, per-channel loop through, and twin HDs. All versions feature common software, full D1/960H recording and HDMI monitor support. In the box The DVR, hard drive screws, SATA lead, manuals, CD-ROM, UK IEC lead, PSU, remote control handset, USB optical mouse. Setting up Adding the hard drive is simple, although requires basic tools, and then setup can be completed rapidly. The Linux based OS fires up in seconds, and the drive was formatted within a minute or two. No issue at all with recognition of the drive. DHCP worked fine but I went for a static address, and then added a dyndns.org username and password with no issues. The netviewer software connected straight away on Windows 7 (64 bit), the GUI of which is identical to the IE or Mac Safari web interface – just note that it’s not currently Chrome compatible. Pleasingly, the ipad and iphone software worked straight away and, after a couple of minor issues, neither of which have ever occurred again, so did the android. A windows phone app is apparently in the works, but there is no indication of when. Bear in mind settings can only be changed with the webserver or the netviewer software, or of course the unit itself. Suffice to say when using the unit directly, with the supplied USB mouse, all orks well; interaction and response to menus etc… is instant. The back panel In use It took only about 10 minutes to have everything set up the way I wanted it; i.e. permissions, users, motion recording etc… There are options for motion activated emails too; on this 4 camera unit, no hardware alarm inputs. There was definitely no need for a manual and the only slightly annoying thing is the ‘line by line’ setup for the cameras etc… rather than seeing them in a grid or table fashion, but there is a copy function that comes in handy. Many budget competitors are no different in this respect. Retrieving footage is a doddle and even the most ‘challenging’ customer should have no issue with this, remotely or otherwise, it even ‘talks’ you through it. The timeline is a little hard to navigate when reviewing motion captured footage until you realise you can ‘zoom in’ by using the scroll wheel on the mouse. Watching all 4 screens in sync is of course not an issue. Footage can be easily exported to a USB stick. Under the hood Running a Linux based operating system, the quality of the PCB and components are as good as any other I’ve seen. The PCB was clean and the SMT components neatly arranged; nothing skewed or covered in stray flux or glue. There are no fans on the 4 channel model. Software Logging on with netviewer 2.0… Netviewer in use… (The IE web browser look and feel is the same) Rxcam for ipad, iphone, and android… Long term test I’ve had my test system up and running for over a month now, and have been very happy with its operation. Whilst my cameras aren’t yet where I’ve wanted them, i.e. outdoors, the motion detect facility has worked well when they have been tripped in their temporary location. I’d have no problem using this for my own customers, and will be using it permanently on my own house alongside some demo Axis units. Summary I would not hesitate to install this system where required for a budget system; at the right discount level you’ll find it less than anything else comparable out there. What’s great? 1. The price – I haven’t seen anything at this price point that performs so well or built as well. 2. Quality images – this doesn’t feel like a cheap, low res budget DVR. 3. Ease of use – you won’t get the customer phoning up in a pickle from a simple operation like reviewing footage. 4. Step up to the HD-SDI models and the interface is identical, no learning how to operate it all over again. Worth pointing out… 1. PSU on this 4 channel version feels a little lightweight. It’s more money, but I’d be half tempted to change it on some jobs for something a bit more substantial. That said, there have been no issues so far. 2. No support for Chrome browser, however, IE and Mac Safari does and there are plenty of reliable and externally maintained tablet and phone apps, which work perfectly. 3. Competition – whilst most rivals at this price will be utter junk, the likes of the barebones Alien range are not that far away. Reassuringly though, this exact same DVR under a brand name sells for twice as much at most outlets to the public; an ‘all in one box’ kit based around this DVR is also sold at some “trade only” electrical wholesalers for a much higher price per component. Being offered it at the Security Warehouse price allows you to still do a pro job for less than the sparky. Room for improvement / wishlist It would be nice to be able to upload a logo and change the colour scheme (currently any colour you’d like, as long as it’s green) to suit your corporate colours. Ditto an ‘installer only’ area to protect and lock such choices. The configuration screens for some of the options could be tidied up so you could see all chosen options at once. But, this isn’t enough to put me off. Manuals and CD-Rom aren’t great; bit Chinglish, but not essential. Conclusion A great value budget DVR that might be useful as an upsell to an intruder system or as a replacement for an older system where you can’t persuade the customer to go for anything higher spec. Specification Display ResolutionPAL: 960×576 @25fps (each channel, Frame)Record ResolutionPAL: D1 mode 360×288 (CIF),720x288 (HD1), 720x576 (D1)960H mode: 480×288 (WCIF),960×288 (WHD1), 960×576 WD1Record SpeedPAL: (each channel) D1 / 960H mode: 25fpsPlayback Channel1/4 ChannelPlayback speed simultaneously 8CH RecordPAL: (each channel) D1 / 960H: 25fpsMobile SurveillanceMobile Phones view based on iPhone, Android, Windows Mobile (TBA) & Blackberry Hope this helps! Edited February 28, 2014 by datadiffusion 1 Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
james.wilson Posted February 28, 2014 Share Posted February 28, 2014 Many thanks for that dd. plus link to the unit you have reviewed here http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=3767 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
datadiffusion Posted February 28, 2014 Author Share Posted February 28, 2014 Might help Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
norman Posted February 28, 2014 Share Posted February 28, 2014 Great review. Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
dazoman1 Posted August 1, 2014 Share Posted August 1, 2014 nice review but what size hdd does that link come with as cant see ? Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted August 1, 2014 Author Share Posted August 1, 2014 None, I buy SV35's at Amazon and the like... http://www.amazon.co.uk/gp/product/B0073Q7GWE/ref=as_li_qf_sp_asin_tl?ie=UTF8&camp=1634&creative=6738&creativeASIN=B0073Q7GWE&linkCode=as2&tag=worldwidemusicre Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
james.wilson Posted August 1, 2014 Share Posted August 1, 2014 it doesnt its a bare machine. most people want to use desktop drives, some want to use red drives, some want to use full on enterprise drives. so i decided it better if the installer fits their own, that way they can choose. plus i wont be able to buy drives much better than an installer. Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Craig Forster Posted August 15, 2014 Share Posted August 15, 2014 Always get u with the hdd Quote Link to comment Share on other sites More sharing options...
Lwillis Posted November 1, 2014 Share Posted November 1, 2014 Can the software on this be branded to show company logos etc? Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted November 1, 2014 Author Share Posted November 1, 2014 Sadly, no. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
