"ticking" Ts700
italypath
Hello,
I have a system with 2x TS700 control panels. It works fine, but when the system is not armed one of the panels makes an irregular but consistent noise rather like a ticking clock. I think the noise stops when the system is armed.
I believe this panel is no longer made, but can anyone suggest someone that could repair it? If not, a simple and (hopefully) cheap replacement.
I am based in north London (N7).
Thanks,
John
I think he means the keypad, I've heard it before on a tsnetled, its data noise.
There are lots of panels that can be used to replace your system, I would recommend the texecom premier elite 24 and 2 keypads for the simple reason that the system you currently have can have 2 zones wired into each keypad and so can the Texecom
True
