Honeywell Ag6 Clicking After Storm
blinkysirens
just to add my 2p diy worth of advice , yes put it in skip even i wouldnt touch em, but in case of the fault suggestion above sounds right , hold of voltage to low or not there, you went out came back, bell used up the internal battery , but then again i went for a repair once where the customer panicked couldnt remember the code, so opened the panel (one of those weird MDT panels mini) disconnected battery removed the mains and back up battery and waited till the bell switched off
and was left with a click click click.....
wheres the skip!
