Galaxy Rf Portal
cant say i have come across the learn setting in the menu or dose it only show up when a portal is installed?
  • Replies 34
  • Views 26.6k
52.2
Select Zone for RF
11.1
Press * then tamper the device.
The serial number will automagically populate.
If the panel is 3 years old you might have compatibility issues, you've only been able to add a portal in the last few years
i have been to the house today to fit the protal and i fitted it on network 2 as there was nothing on it and address it as 0. if i go on to rss it shows up as rio rf 200 but on the zones it is showing up as 104 and 105 which was unused???
is this ok?
