Gemini Posted June 17, 2011 Share Posted June 17, 2011 This is a 24v bell. What amperage does it require? (the transformer) Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted June 17, 2011 Share Posted June 17, 2011 This is a 24v bell. What amperage does it require? (the transformer) 30mA @ 24Vdc (Gent 12141-01) Link to comment Share on other sites More sharing options...
Gemini Posted June 17, 2011 Author Share Posted June 17, 2011 That is excellent. I am actually trying to find an inexpensive transformer. Any ideas? Link to comment Share on other sites More sharing options...
Adi Posted June 17, 2011 Share Posted June 17, 2011 you could look for a robot in disguise I really can't be ar**** with it anymore. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted June 18, 2011 Share Posted June 18, 2011 I am actually trying to find an inexpensive transformer. Any ideas? I don't think there's a transformer inside a bell. There would either be a small DC motor or a solenoid. What do you want the "transformer" for. Link to comment Share on other sites More sharing options...
norman Posted June 18, 2011 Share Posted June 18, 2011 I'm guessing to drop from 230v ? Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
Gemini Posted June 19, 2011 Author Share Posted June 19, 2011 I was considering getting this bell just for a bit of fun, not to install. I gather the "transformer" would usually be built into the control panel in an installation. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted June 19, 2011 Share Posted June 19, 2011 I was considering getting this bell just for a bit of fun, not to install. I gather the "transformer" would usually be built into the control panel in an installation. The fire alarm panel has a power supply to power the panel, devices and upon a fire condition the bell/sounders. You would require a 24Vdc power supply capable of supplying over 30mA. Unfortunatly 24Vdc is a voltage only used on a limited amount of equipment. Or get a 12Vdc bell and power supply? Link to comment Share on other sites More sharing options...
nexlar Posted September 3, 2012 Share Posted September 3, 2012 The fire alarm panel has a power supply to power the panel, devices and upon a fire condition the bell/sounders. You would require a 24Vdc power supply capable of supplying over 30mA. Unfortunatly 24Vdc is a voltage only used on a limited amount of equipment. Or get a 12Vdc bell and power supply? Is it okay with 24Vdc power supply. I have a doubt in my mind. Link to comment Share on other sites More sharing options...
Oxo Posted September 3, 2012 Share Posted September 3, 2012 Why? What difference is a 24vdc PSU to the panel bell outputs, which run off a 24vdc supply? Link to comment Share on other sites More sharing options...
