7VEN Posted December 30, 2010 Share Posted December 30, 2010 As above, can anyone reccomend an internal sounder that can be recessed into the ceiling cavity? Kind regards Link to comment https://www.thesecurityinstaller.co.uk/community/topic/30540-recessed-internal-sounder-for-honeywell-galaxy-48/ Share on other sites More sharing options...
james.wilson Posted December 30, 2010 Share Posted December 30, 2010 Use a flush mount pa speaker securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/30540-recessed-internal-sounder-for-honeywell-galaxy-48/#findComment-263608 Share on other sites More sharing options...
breff Posted December 30, 2010 Share Posted December 30, 2010 just make sure its 16 ohm, or use 2x 8ohm in series The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/30540-recessed-internal-sounder-for-honeywell-galaxy-48/#findComment-263663 Share on other sites More sharing options...
Guest Oxo Posted December 30, 2010 Share Posted December 30, 2010 Someone give Jeff a shout I think hes sourced one for this specific. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/30540-recessed-internal-sounder-for-honeywell-galaxy-48/#findComment-263677 Share on other sites More sharing options...
7VEN Posted December 31, 2010 Author Share Posted December 31, 2010 Someone give Jeff a shout I think hes sourced one for this specific. Jeff, Thoughts? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/30540-recessed-internal-sounder-for-honeywell-galaxy-48/#findComment-263768 Share on other sites More sharing options...
james.wilson Posted December 31, 2010 Share Posted December 31, 2010 The Bosch LBC3090/31 is a 6w speaker that is flush mount but is only 4 Ohms. Many panels will drive 8 Ohms but not 4 securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/30540-recessed-internal-sounder-for-honeywell-galaxy-48/#findComment-263772 Share on other sites More sharing options...
sixwheeledbeast Posted December 31, 2010 Share Posted December 31, 2010 The Bosch LBC3090/31 is a 6w speaker that is flush mount but is only 4 Ohms. Many panels will drive 8 Ohms but not 4 Maybe a 10 watt 12 ohm resistor in series, that would work. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/30540-recessed-internal-sounder-for-honeywell-galaxy-48/#findComment-263812 Share on other sites More sharing options...
james.wilson Posted January 1, 2011 Share Posted January 1, 2011 I'd have to calculate it. It's impedance we need to worry about here not resistance as such. As it's a dimension it would run 2 of these in series, but not 1 directly. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/30540-recessed-internal-sounder-for-honeywell-galaxy-48/#findComment-263834 Share on other sites More sharing options...
sixwheeledbeast Posted January 1, 2011 Share Posted January 1, 2011 I'd have to calculate it. It's impedance we need to worry about here not resistance as such. As it's a dimension it would run 2 of these in series, but not 1 directly. I understand your concern, it was a rough suggestion. Unfortunately is not easy to calculate the exact impedance of a circuit without the frequency ranges of the panel. Manufactures impedance is based by roughly guessing the applications freq. range anyway. But I was sure that inductors and capacitors differ between resistance and impedance but a resistance effects an AC wave the same as DC. Therefore I would be sure of getting a similar impedance although due to being a divider may roughly 1/2 or 5/8 the volume. Vo=Vi(R/(R+Z)) This is not recommended for PA or Music applications etc, due to loss in power equals loss of quality/output which is a waste. Alternatively running it through an audio transformer of correct impedance values. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/30540-recessed-internal-sounder-for-honeywell-galaxy-48/#findComment-263862 Share on other sites More sharing options...
reidy Posted January 2, 2011 Share Posted January 2, 2011 http://www.knightplastics.com/view_item.asp?id=41 Came across these if anyone's still interested Hey Ho, Lets Go Link to comment https://www.thesecurityinstaller.co.uk/community/topic/30540-recessed-internal-sounder-for-honeywell-galaxy-48/#findComment-263981 Share on other sites More sharing options...
