InspectorGadget Posted May 4, 2009 Share Posted May 4, 2009 HI, I have been running a Texecom Premier 48 for about a year now with a PIR as the Entry/Exit 1 which has worked fine, when you arm the panel and walk out the secondary arm tones start when the PIR picks up movement. This weekend I have installed a read switch to the front door, set this to Entry/Exit 1. All works fine. however on re-entry when the front door opens the entry/exit process starts and about 2 seconds later the panel goes to full alarm, checking the log the PIR in the hall way is setting this off. I have changed the Zone1 from "Entry/Exit 1" to "Guard Access" and this still results in an alarm condition when re-entering. I am gathering that the PIR is picking up the door opening before the reed switch is activating the entry/exit process. If I change the Zone1 to "Guard" with the attribute 1 "access" then the same happens. Is there an easy fix - I would like to continue using the PIR if I can rather than just disabling it. Thanks Link to comment Share on other sites More sharing options...
Dandle Posted May 4, 2009 Share Posted May 4, 2009 The pir should be set to guard access and the door contact to entry exit. Link to comment Share on other sites More sharing options...
breff Posted May 4, 2009 Share Posted May 4, 2009 Also make sure the door contact is a lower zone number than the pir. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
A-G Posted May 4, 2009 Share Posted May 4, 2009 Also make sure the door contact is a lower zone number than the pir. Why so Breff? . . . PM me for access to the SSAIB members discussion area. Link to comment Share on other sites More sharing options...
magpye Posted May 4, 2009 Share Posted May 4, 2009 Also make sure the door contact is a lower zone number than the pir. I don't use the Premier so I don't know. Why does the door contact have to be on a lower zone number than the PIR, surely the zone attributes should be all that is needed? Is it really that critical with this panel? magpye Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care. Link to comment Share on other sites More sharing options...
james.wilson Posted May 4, 2009 Share Posted May 4, 2009 it is with most, if not all panels. The panel processes signals in order so if 2 signals come in at the same time it will action the lower number first. One thing the castle is good for here as it waits 5 seconds after an exit has gone waiting for an entry circuit. Cracking idea god knows where or who it came from... securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
A-G Posted May 4, 2009 Share Posted May 4, 2009 it is with most, if not all panels.The panel processes signals in order so if 2 signals come in at the same time it will action the lower number first. I never knew that .... but we always put doors on the first zones, so it isn't a problem that we would ever have noticed. . . . PM me for access to the SSAIB members discussion area. Link to comment Share on other sites More sharing options...
JamesMichaelson Posted May 5, 2009 Share Posted May 5, 2009 I never knew that .... but we always put doors on the first zones, so it isn't a problem that we would ever have noticed. Neither did I, I was told by the guys at xxxxxxxxxxxxxxxxxxxxx that it was possible but I might give em a ring again. We'll see Link to comment Share on other sites More sharing options...
A-G Posted May 5, 2009 Share Posted May 5, 2009 I checked with Texecom. They confirmed James' explanation ... and added that this problem has only surfaced relatively recently because the panels and movement detectors have become so fast ... faster than the mechanical door contacts can operate. . . . PM me for access to the SSAIB members discussion area. Link to comment Share on other sites More sharing options...
Guest RJBsec Posted May 5, 2009 Share Posted May 5, 2009 In the past it was a problem with Menvier panels (e.g. TS690iD) where the final exit was taken off one of the keypad zones, (zone 31 or 32), and entry was zone 1-8; Menvier changed the software to compensate. Link to comment Share on other sites More sharing options...
