Guest BlindTrust
Hi
Has anyone actually used this? How well does it work? How easy/hard is it to programme a key fob? Can you programme a key fob?
Also I'm looking fir a control panel that can be connected to a computer for alarm notification and/or remote control. Does anyone have any ideas?
BT
https://www.thesecurityinstaller.co.uk/community/topic/1509-ade-simple-set/
The Texecom Premier 48 Can be connected to a PC and they do a proximity keypad
  • 3 weeks later...
  • 12 years later...
19 minutes ago, diyer said:
Wonder if anyone has installed 2 or 3 of these ADE Simple set readers in one installation? Can you learn a single keyfob to all 3 readers or do you need to have keyfobs for each one? Hope it's not the latter!
You don't need separate fobs for each reader you can use the same one on all three.  These are stand alone units (in so far as remembering the fob hex code) that only store the fob locally not at panel level, like other systems.
Every decent modern alarm offers this feature, at least as a mainstream or virtually no-cost option, and you DON'T have reprogramme at every 'keypad'!
The ADE SS was a kludge hence why each reader simply emulates a standard ADE keypad and the key has to be re-progged on each one.
It was presumably discontinued due to very low uptake and the fact that even the cheapest rival panel can do the same thing for less money, plus have LCD full screen text.
As above Texecom would probably be your best bet.
thanks for the update datad.. hmm I seem to have failed to realize that many rkp's incorporate a prox reader as well hence the poor uptake of the ADE device as you say. I wounder if the texecom prox reader keypads would be compatible with an ade gen4 panel? say the DBC-0001 for example?
Register a new account
Sign in
