Guest BlindTrust Posted February 24, 2004 Share Posted February 24, 2004 Hi Has anyone actually used this? How well does it work? How easy/hard is it to programme a key fob? Can you programme a key fob? Also I'm looking fir a control panel that can be connected to a computer for alarm notification and/or remote control. Does anyone have any ideas? BT Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1509-ade-simple-set/ Share on other sites More sharing options...
breff Posted February 25, 2004 Share Posted February 25, 2004 The Texecom Premier 48 Can be connected to a PC and they do a proximity keypad The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1509-ade-simple-set/#findComment-7913 Share on other sites More sharing options...
Guest lev Posted March 12, 2004 Share Posted March 12, 2004 Simple set is as the name implies, simple to use. It can be used on any panel that has a keyswitch input or is fully compatible with the ADE Optima/Accenta G3 panels. It only sets and unsets a system, nothing more. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1509-ade-simple-set/#findComment-9129 Share on other sites More sharing options...
Guest BlindTrust Posted March 14, 2004 Share Posted March 14, 2004 Thanks Lev I have gobe for a Gardtec 800 as it appears to do everything I want. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1509-ade-simple-set/#findComment-9211 Share on other sites More sharing options...
diyer Posted August 22, 2016 Share Posted August 22, 2016 Wonder if anyone has installed 2 or 3 of these ADE Simple set readers in one installation? Can you learn a single keyfob to all 3 readers or do you need to have keyfobs for each one? Hope it's not the latter! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1509-ade-simple-set/#findComment-449515 Share on other sites More sharing options...
dufjax Posted August 22, 2016 Share Posted August 22, 2016 19 minutes ago, diyer said: Wonder if anyone has installed 2 or 3 of these ADE Simple set readers in one installation? Can you learn a single keyfob to all 3 readers or do you need to have keyfobs for each one? Hope it's not the latter! You don't need separate fobs for each reader you can use the same one on all three. These are stand alone units (in so far as remembering the fob hex code) that only store the fob locally not at panel level, like other systems. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1509-ade-simple-set/#findComment-449516 Share on other sites More sharing options...
diyer Posted August 23, 2016 Share Posted August 23, 2016 Thanks dufjax - good to hear that. Anyone know why these units have been discontinued now? I don't seem to be able to find a simple alternative. Surely keyfob alarm setting with a remote unit like these is a useful feature which no other device seems to offer. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1509-ade-simple-set/#findComment-449546 Share on other sites More sharing options...
datadiffusion Posted August 23, 2016 Share Posted August 23, 2016 Every decent modern alarm offers this feature, at least as a mainstream or virtually no-cost option, and you DON'T have reprogramme at every 'keypad'! The ADE SS was a kludge hence why each reader simply emulates a standard ADE keypad and the key has to be re-progged on each one. It was presumably discontinued due to very low uptake and the fact that even the cheapest rival panel can do the same thing for less money, plus have LCD full screen text. As above Texecom would probably be your best bet. So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1509-ade-simple-set/#findComment-449548 Share on other sites More sharing options...
diyer Posted August 23, 2016 Share Posted August 23, 2016 thanks for the update datad.. hmm I seem to have failed to realize that many rkp's incorporate a prox reader as well hence the poor uptake of the ADE device as you say. I wounder if the texecom prox reader keypads would be compatible with an ade gen4 panel? say the DBC-0001 for example? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1509-ade-simple-set/#findComment-449550 Share on other sites More sharing options...
james.wilson Posted August 23, 2016 Share Posted August 23, 2016 no securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1509-ade-simple-set/#findComment-449551 Share on other sites More sharing options...
