- Past hour
Eric801 joined the community
9651 started following Shunt locks
1231afa joined the community
Xuper IT joined the community
Its a two year old thread I doubt that he will reply. In answer to your question. In most cases hard wired detectors are compatible with any brand of panel, you will most likely have to change end of line resistors along with the panel. - Earlier
HitenD joined the community
monena joined the community
riccardo joined the community
Who's Online 2 Members, 0 Anonymous, 79 Guests (See full list)
Total Topics446.4k
