If you keep pressing the info/OK button it should run through the faults. If the faults are clear it will let you arm/disarm to clear. - Yesterday
monena joined the community
riccardo joined the community
al-yeti started following door/window opening detectors with fixed tamper alarm on lightsys
Who's Online 0 Members, 0 Anonymous, 53 Guests (See full list)
Total Topics446.3k
