LewisLewLew3492 joined the community
Eric801 joined the community
9651 started following Shunt locks
1231afa joined the community
Xuper IT joined the community
HitenD joined the community
monena joined the community
You are not reading what he typed correctly he typed "with the panel and sensors pulling 0.55 A" Now there was no mention of mA so 0.55A no matter how you try to dress that up is slightly over half an amp. He may have made a mistake but either way what he typed is 0.55A not 0.055A which would be 55mA
Who's Online 0 Members, 0 Anonymous, 65 Guests (See full list)
Total Topics446.4k
