- Past hour
Guard Access ?
Thank you Mr Happy...... I have this morning programmed zones 1 to 8 as normally closed and am now able to use the alarm........ Your help has been much appreciated, thank you. Regards. - Yesterday
Its a two year old thread I doubt that he will reply. In answer to your question. In most cases hard wired detectors are compatible with any brand of panel, you will most likely have to change end of line resistors along with the panel.
Who's Online 2 Members, 0 Anonymous, 78 Guests (See full list)
Total Topics446.4k
