- Past hour
Its a two year old thread I doubt that he will reply. In answer to your question. In most cases hard wired detectors are compatible with any brand of panel, you will most likely have to change end of line resistors along with the panel. - Today
If you keep pressing the info/OK button it should run through the faults. If the faults are clear it will let you arm/disarm to clear. - Last week
Thats half an amp in my book
Who's Online 1 Member, 0 Anonymous, 49 Guests (See full list)
Total Topics446.4k
