- Past hour
It does both. Allowing walk through for Full set and switching to entry for Part sets. - Today
Thanks for the reply. Regarding the guard access, as far as I can make out this only allows you to pass through a zone on your way to the keypad once the entry timer has been tripped. The problem I'm having is that in part set (Going to bed) I require zones 1, 2, 3, 4, 5 and 8 (All of downstairs and upper rear bedroom windows) to be active, zone 7 (Landing) to be off and zone 6 (Stairs) to be timed. The idea being that we are able to move across the landing in the night to visit the bathroom and then when going downstairs in the morning the stairs sensor will trip the timer to remind certain individuals to disarm the system. The reason behind this is that on numerous occasions in the past these certain individuals would walk down the stairs, right past the keypad at the bottom of the said stairs and into the living room, thus triggering a full alarm and therefore awakening the whole house, by adding a sensor on the stairs that trips the timer, I hope to overcome this. (Although having known these certain individuals for quite some time, this is by no means a certainty........ !) As mentioned earlier, I can select the "Alter Part Arms" menu and select each zone to be on or off in part set, but on or off are the only options available for the zones in that menu, there are no other options like setting a zone to be timed or entry / exit. I've looked through all of the programming menus and cannot find anywhere that gives me an option to program zone 6 as timed or entry / exit when the system is part set. I'm certain that this can be done, it's just that I can't suss out how.......... So it's back over to the good folk on here to hopefully help me over the line with this one...... Regards, dave. - Yesterday
Guard Access ?
Thank you Mr Happy...... I have this morning programmed zones 1 to 8 as normally closed and am now able to use the alarm........ Your help has been much appreciated, thank you. Regards. - Last week
Who's Online 3 Members, 0 Anonymous, 82 Guests (See full list)
Total Topics446.4k
