If you keep pressing the info/OK button it should run through the faults. If the faults are clear it will let you arm/disarm to clear. - Earlier
Thats half an amp in my book
Who's Online 2 Members, 0 Anonymous, 72 Guests (See full list)
Total Topics446.4k
