  1. Yesterday
  11. Last week
  13. Thank you and oh no the evil mod team lol
  14. 4700(496383_iss_1).pd Gotham postcode ?? oh noun..... attached appear to be from the grey workshop manual.... download it quick before the evil mod team remove it
  15. Ankle tag & 7too7 curfew ? Nah am living in a abandoned hospital my mate bought though Its so old the only manuals i can find are in French
  16. Ankle tag & 7too7 curfew ? is it listed in the grey "workshop" manual, as the product is much older than pdf files ?
  17. I'm pretty sure the guy has tried this but I'll get my mate to have a look with me and give it a try myself. Thank you for your help.
  18. Earlier
  19. To put that in english: Type the user code that works, press no till you get to CD press Yes then enter the four digits you want to use, and again a second time to confirm
  20. this shows the process
  21. Both the engineers code and the default user code allow me to access the control panel (the box that enables you to activate / deactivate the alarm) however as far as I can tell by the user manual I have, neither codes allow me to change the alarm set / unset code which is personal to myself. It must be able to be changed as it was changed when the system was installed in the property.
  22. If you have no code that works then you wont be able to change the code. If you could change the code without knowing what it is to begin with, anyone could just change your code while your back is turned.
  23. I have used the default user code and I don't get anywhere. There seems to be no steps in the manual to personalise your alarm code.
  26. Jack b
    Internal of the 41A
  27. It sounds like the panel may have defaulted, you need the default user code rather than the engineer code. I dont know the panel but would guess the default user will be 1234 or 0123 or 4567 or 2222 or similar. There is not alot of info in the user manual and the panel is very old and obsolete
  • Who's Online   1 Member, 0 Anonymous, 50 Guests (See full list)
    52,049
    David R
    David R
    446.6k
