Help needed with Wiring Odyssey siren to Visonic powermax
Hi All,
I did read many post on the forum before starting this one so please excuse me im im repeating someone else question.
Im in the middle of trialing a Texecom Odyssey bell box (X-BE) with a visonic powermax complete.
I have connected the expander module and that works fine as I also tested a voice box.
Now, when it comes to this siren im getting a strange tamper issue. When I open the lid to to release the tamper on the siren the powermax complete panel shows no trouble lights but still says Not ready to arm (z30 open)
however I have the siren ringing (because the tamper is open). Weirdly when I close the tamper on the siren the trouble light flicks on and says Z30 is open.
I have connected it just as Visonic have said and also enrolled Zone 30 as 24h Audible.
connections on Siren to expander
A: 12V+ >>>> SRN+
B: Bell >>>> EXT
C: Tamp >>>> Z30
D: 0V >>>> GND
S: STRB >>>> IN-
I have also linked the Tamp with a 2.2K resistor to 0V in the siren aswell use an addition 2.2K resistor inline with z30 on the expander.
Could someone tell me if im doing anything wrong?
Any help would be appreciated.
Link to comment
Share on other sites
@petrolhead I have installed hundreds or powermax complete systems but never come across someone wanting a different style bell hence why I want to trial this before considering this any further. Also, its not a paid job as I have not agreed to anything yet but I was keen to understand how it would work out.
Link to comment
Well you have the wiring diagram, looks pretty simple. Done this with other makes of bells before no problem.
Is the bell going into hold off mode, look at the Ody LED's when your opening/closing the tamper.
Measure the resistance of the tamper loop with lid in different states so you can see what the reading are at the panel.
You may have to adjust your resistances to accommodate the bell.
I wouldn't have thought it was a ground issue as I would assume they are at the same potential via the ribbon lead?
Link to comment
