crispylees Posted June 23, 2025 Share Posted June 23, 2025 Hi, My ancient Accenta8 alarm panel has given up and I plan to replace it with a Texecom Premier Elite 24. I have swapped all the original PIRs for Honeywell IS312 as I decorated each room. Are PIRs basically standard and compatible with most alarms or do I need to replace the PIRs if I install the Texecom panel? Thanks Chris Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47316-newbie-questionpir-compatibility/ Share on other sites More sharing options...
sixwheeledbeast Posted June 23, 2025 Share Posted June 23, 2025 Should be compatible if you wired as double pole with commoned tampers. I'd probably replace them. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47316-newbie-questionpir-compatibility/#findComment-530279 Share on other sites More sharing options...
crispylees Posted June 23, 2025 Author Share Posted June 23, 2025 Thanks for the quick reply. Just been an expensive month - car, washing machine and alarm in the same week!!! Trying to keep costs down What's your reasoning behind replacing them...reliability? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47316-newbie-questionpir-compatibility/#findComment-530280 Share on other sites More sharing options...
al-yeti Posted June 23, 2025 Share Posted June 23, 2025 1 hour ago, crispylees said: Hi, My ancient Accenta8 alarm panel has given up and I plan to replace it with a Texecom Premier Elite 24. I have swapped all the original PIRs for Honeywell IS312 as I decorated each room. Are PIRs basically standard and compatible with most alarms or do I need to replace the PIRs if I install the Texecom panel? Thanks Chris You don't have to unless they give you trouble , although it's probably more of DIY product now with it's problems Just wire them double pole or correct resistors in place latter best way to go Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47316-newbie-questionpir-compatibility/#findComment-530282 Share on other sites More sharing options...
PeterJames Posted June 23, 2025 Share Posted June 23, 2025 Use a bucket, soap and sponge instead of buying a car washing machine! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47316-newbie-questionpir-compatibility/#findComment-530283 Share on other sites More sharing options...
sixwheeledbeast Posted June 23, 2025 Share Posted June 23, 2025 If you get the same manufacturer as the panel you will have EOL OOTB. I don't really rate those cheap Honeywells, some nice quads will be much more reliable. Much better down the line to have end-of-line than double pole to diagnose faults. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47316-newbie-questionpir-compatibility/#findComment-530291 Share on other sites More sharing options...
