monena Posted May 3 Share Posted May 3 Hello Everyone, After a very long renovation and subsequent complete rewiring of the alarm system, I have returned to activating the lightsys alarm. Unfortunately, however, some door opening detection sensors, connected via radio, continuously give the tamper alarm. In particular, 3 sensors out of 9 have this problem. What could have happened? I have already changed all the battery. Thanks for your availability. Best regards Simone Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47232-doorwindow-opening-detectors-with-fixed-tamper-alarm-on-lightsys/ Share on other sites More sharing options...
al-yeti Posted May 3 Share Posted May 3 45 minutes ago, monena said: Hello Everyone, After a very long renovation and subsequent complete rewiring of the alarm system, I have returned to activating the lightsys alarm. Unfortunately, however, some door opening detection sensors, connected via radio, continuously give the tamper alarm. In particular, 3 sensors out of 9 have this problem. What could have happened? I have already changed all the battery. Thanks for your availability. Best regards Simone Plastics? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47232-doorwindow-opening-detectors-with-fixed-tamper-alarm-on-lightsys/#findComment-529393 Share on other sites More sharing options...
MrHappy Posted May 3 Share Posted May 3 open then then close the door after replacing the lid (if you have the lid on properly?) Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47232-doorwindow-opening-detectors-with-fixed-tamper-alarm-on-lightsys/#findComment-529395 Share on other sites More sharing options...
james.wilson Posted May 3 Share Posted May 3 3 hours ago, MrHappy said: open then then close the door after replacing the lid (if you have the lid on properly?) Or get better equipment securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47232-doorwindow-opening-detectors-with-fixed-tamper-alarm-on-lightsys/#findComment-529399 Share on other sites More sharing options...
Paulsen97 Posted May 8 Share Posted May 8 Hey @monena, It sounds like you're dealing with persistent tamper alerts on your wireless door/window sensors after your renovation. Even though you've replaced the batteries, there are a few other factors that might be causing this issue: Tamper Switch Alignment: Ensure that the tamper switches on the sensors are properly engaged. If the sensor covers aren't seated correctly, the system might interpret this as a tamper condition. Physical Mounting: Check that the sensors are securely mounted. Loose fittings or misaligned magnets can trigger false tamper alerts!! Environmental Factors: Since you've had a renovation, it's possible that environmental changes (like new materials or layouts) are affecting the sensors' performance. For instance, certain materials can interfere with wireless signals, leading to communication issues that the system might interpret as tampering. Sensor Quality: Sometimes, the quality of the sensors themselves can be a factor. If the sensors are older or of lower quality, they might be more prone to false tamper alerts. If you've checked all these and the issue persists, it might be worth consulting with a professional to inspect the system. They can provide a more in-depth analysis and suggest potential replacements if necessary. Hope this helps! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47232-doorwindow-opening-detectors-with-fixed-tamper-alarm-on-lightsys/#findComment-529491 Share on other sites More sharing options...
monena Posted December 6 Author Share Posted December 6 I have tested all the sensors, i have 10 different Door sensors. But only two have the tamper problem. I have also removed the sensors from the radio list. Now the problem is that without tamper communication i am unable to re-add the removed sensors. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47232-doorwindow-opening-detectors-with-fixed-tamper-alarm-on-lightsys/#findComment-531389 Share on other sites More sharing options...
al-yeti Posted December 6 Share Posted December 6 44 minutes ago, monena said: I have tested all the sensors, i have 10 different Door sensors. But only two have the tamper problem. I have also removed the sensors from the radio list. Now the problem is that without tamper communication i am unable to re-add the removed sensors. Pictures , makes and models and what does log say Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47232-doorwindow-opening-detectors-with-fixed-tamper-alarm-on-lightsys/#findComment-531390 Share on other sites More sharing options...
monena Posted December 6 Author Share Posted December 6 The sensors are risco original. The models are 1PCT72X00000H. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47232-doorwindow-opening-detectors-with-fixed-tamper-alarm-on-lightsys/#findComment-531392 Share on other sites More sharing options...
MrHappy Posted December 6 Share Posted December 6 sensors have no reverse polarity protection, a short while with the battery the wrong way break them, IIRC they light up but won't learn on Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47232-doorwindow-opening-detectors-with-fixed-tamper-alarm-on-lightsys/#findComment-531394 Share on other sites More sharing options...
