you should only need red and black connected as per that drawing. The strobe is something else
Thanks James. Connected per your recommendation and nothing happening. Closing the tamper switch has no effect. Battery is connected and at 6.34 V. Any thoughts?
Open IMG_4996.pdf
Tamper connection?
So 12v connected to Bell + and hold off?
Here’s the solution. Make sure the battery is disconnected. Disconnect the tamper switch and bridge it out. LEDs alternating back and forth.
Screenshot 2025-12-03 at 16.31.33.pdf
